73 dash bezel
The wood grain on the dash bezel of the 73 I'm working on is all tore up. When I look for an aftermarket bezel, it seems that there is none for 73, or 74? Anyone know what will work for this 73?
77 k10 winter beater build http://67-72chevytrucks.com/vboard/s...d.php?t=716884 85 GMC short fleet budget build http://67-72chevytrucks.com/vboard/s...d.php?t=714222 80 C10 stepside build http://67-72chevytrucks.com/vboard/s...d.php?t=693848 |
Re: 73 dash bezel
I believe the 75 through 77 bezels will fit 73 & 74. And so will the 78 through 80 bezels as long as you use the matching cover panel that fits below the steering column.
But there are few differences. For example, the 75+ bezels have a slightly wider rectangular opening for the windshield wiper switch. And the 75+ bezels no longer have the slightly raised up section surrounding the headlight switch knob and instead have a larger round hole. The appearance/styling also changed a bit, especially with the 78+ bezels. |
Re: 73 dash bezel
This should help
http://bowtieguy.proboards.com/threa...ce-bezels-fits E-bay maybe the place to look, if you want to keep it factory
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
#4 | |
Happy to be here
![]() Join Date: Mar 2000
Re: 73 dash bezel
