Old 03-13-2017, 03:59 PM   #1
Afirehawk1
Radiator Hoses
I am running a 1967 - 396 with a short water pump and an engineering cooling products radiator (speed cool); any suggestions on findings radiator hoses that would work?
Afirehawk1 is offline   Reply With Quote
Old 03-13-2017, 05:39 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Radiator Hoses
Do you have an older, independent auto parts store near you that will allow you to look in the back or stockroom for a couple of hoses that have the correct basic bends and contours (you may have to trim what you find)? I usually draw out the length and note the bends that I need, and there is an old Napa store near me that has hundreds of hoses that I can pick through. I recently had to do this for a Pontiac restoration project where there are no longer any refrenceable part numbers.
If not, the other route that I take is making mine from leftover steel J- and U-bend tubing, making pie cuts, and welding them together for the compound bends. I did this for my C10 (radiator tubing between my zoomies) and my old Super Gas drag car, using short pieces of hose for the connections:
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-13-2017, 06:40 PM   #3
Afirehawk1
Re: Radiator Hoses
Good info
Old 03-13-2017, 11:35 PM   #4
Captainfab
60-66 Nut
Re: Radiator Hoses
Depending on what radiator you are running, you may be able to make use of the hoses for a '68-'71 C10/20/30with a 396/402. When I put the 454 in my '66 Suburban, I did the same thing Vin63 said. I went to a local auto parts store and hunted thru a bunch of hoses until I found a couple I could cut up and make work.
Old 03-14-2017, 09:58 AM   #5
conquistador
I just had a new radiator installed and my mechanic said he used late 60's Camarillo hoses. You might check with that. The looked like they belonged on the engine.
conquistador is offline   Reply With Quote
Old 03-14-2017, 10:08 AM   #6
Afirehawk1
Re: Radiator Hoses
Ok now im puzzled
What the heck is a Camarillo?
Old 03-14-2017, 11:35 AM   #7
PGSigns
PGSigns's Avatar
Re: Radiator Hoses
It's a city in California. Must make hoses there.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-14-2017, 01:14 PM   #8
Mackie
Mackie's Avatar
Re: Radiator Hoses
Gotta love auto-correct.
Camarillo is the home of that Horrible Fright Co
`63 C-10 Shortwide
Roller 305 LT1 cam, Eddy 500
T5
Mackie is offline   Reply With Quote
Old 03-14-2017, 01:15 PM   #9
61K10
61K10's Avatar
Re: Radiator Hoses
a pic of your rad and the size of the outlets would help. I would say BB chevelle 66-67. might have to trim some, if they fit the outlets.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 03-14-2017, 04:22 PM   #10
forestb
forestb's Avatar
Re: Radiator Hoses
Originally Posted by Afirehawk1 View Post
Ok now im puzzled
Just in case you are still stumped I think he meant Camaro. But you might already know that.
forestb is offline   Reply With Quote
Old 03-14-2017, 08:32 PM   #11
Afirehawk1
Re: Radiator Hoses
Great info gang. Many thanks!!
Old 03-15-2017, 07:30 AM   #12
conquistador
Re: Radiator Hoses
Sorry, you are right, I meant Camaro. Fat fingers, little keyboard, and I have invented Chevy's next smart car the Camarillo.
Old 03-15-2017, 08:40 AM   #13
Afirehawk1
Re: Radiator Hoses
Im a Camaro guy at heart
Many thanks
