03-13-2017, 06:04 PM | #1 |
spring at the base of the steering column
does anyone know where i can get a spring for the base of the steering column... im in canada. you know the ont that goes between the the steering column and the shaft inside under the hood. i dont need the stock one just one that will do the job.
03-13-2017, 07:02 PM | #2 | |
The Older Generation
Re: spring at the base of the steering column
LockDoc
03-13-2017, 07:13 PM | #3 |
What's that spring about, anyway? It's clearly there to preload the washer but what's the purpose of that, I wonder?
03-13-2017, 07:23 PM | #4 | |
Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
03-13-2017, 07:24 PM | #5 | |
It doesn't preload the washer, it preloads the bearing in the bottom of the column. If the washer and spring weren't there you would be able to pull the steering wheel up towards you until the flex joint hit the bottom of the column, about an inch. LockDoc
03-13-2017, 07:48 PM | #6 |
yes sir that is the spring. and yes that washer is a must .. just like he said if you dont have them you can pull the whole wheel in the cab up about a inch or so. any idea where i should look for one???
03-13-2017, 07:54 PM | #7 | |
Anyone that sells used parts should have one. If you can find one in Canada you would be better off. The postage from the US to Canada is killer.... There are quite a few members from Canada on here. Check this forum out.... http://67-72chevytrucks.com/vboard/f...sprune=-1&f=63 LockDoc
