Old 03-13-2017, 09:10 PM   #1
Axlereid
1966 C-10 4 Speed Floor Shifter
Anyone have a line on a stock floor shifter for a 1966 C-10?
Can't seem to locate one in any of the online sources.
In So/Cal area.
Thanks!
Axlereid is offline   Reply With Quote
Old 03-13-2017, 10:05 PM   #2
Blue666(2)
Re: 1966 C-10 4 Speed Floor Shifter
Floor shift for three speed, four speed or automatic? What type trans?
Blue666(2) is offline   Reply With Quote
Old 03-13-2017, 10:10 PM   #3
MikeN
MikeN's Avatar
Using a Hurst Mastershift on the heavy duty 3-speed Muncie in my 64 C10. Nice shifter - very satisfied.
MikeN is offline   Reply With Quote
Old 03-13-2017, 11:40 PM   #4
Captainfab
60-66 Nut
Are you needing a shifter for an original SM420 4 speed trans?
Old 03-14-2017, 12:23 AM   #5
Axlereid
Swapping 3 on tree for M-21 Muncie but wanting stock floor shifter. Not sure if it's adaptable but would like to try that first to maintain original look.
Old 03-14-2017, 12:24 AM   #6
Axlereid
M-21 Muncie 4 speed. Was originally 3 on tree
Old 03-14-2017, 06:30 PM   #7
Blue666(2)
This kit would get you every thing you need. As it fits a few different transmissions, you will have some kit left over.
https://www.summitracing.com/parts/cmb-13-0074
I would shop around to find the best price. As the Hurst patents have expired, there are likely a few generic copies available. Mr. Gasket & ITM also had different versions. Many people probably also have used units available.
Good Luck!
Old 03-14-2017, 11:47 PM   #8
Captainfab
60-66 Nut
These trucks did not come stock with any kind of a floor shifter for a manual trans of that style. You will have to go with an aftermarket shifter. Choosing a shifter will also depend on what seat arrangement you are planning.
Old 03-15-2017, 12:24 AM   #9
oem4me
I've got a whole SM420 4 speed with shifter included. Not exactly an easy adaption to a different trans, as the levers/forks are internal. see pic in the link. http://67-72chevytrucks.com/vboard/s...d.php?t=729485
Old 03-15-2017, 01:44 PM   #10
61K10
61K10's Avatar
T&F shifter. only one that would put in in the forward position. about the same as the granny 4sp location. Don't know if they are still avl.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
