03-13-2017, 10:31 PM | #1 |
Tail light gaskets???
Ok so i have ordered tail light gaskets from 2 different vendor's and I keep getting foam gaskets. Where can you get the oe rubber style? This is making me mad😠
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
03-14-2017, 06:57 AM | #2 |
Re: Tail light gaskets???
Would like to know also, may be able to find a material to make our own
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
03-14-2017, 07:53 AM | #3 |
I buy black closed cell foam to use when restoring the vent flappers inside the a/c heat airbox under the dash . It comes in a multitude of thicknesses and shapes easy with an X-acto knife or just a razor blade .
03-14-2017, 12:49 PM | #4 |
Active Member
Grump, what do you use to re-staple thru the metal on the flappers?
03-14-2017, 01:04 PM | #5 |
I remember my rubber inner fender flappers on my 64 Impala were attached by staples and I had to buy them separately and hand bend them.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
03-14-2017, 01:19 PM | #6 |
I sealed the tail lights on my dad's VW Dune buggy by using a Rubber sealant aka RTV, you want to get the stuff that drys 100%. I sprayed PAM anti stick spray on the old gasket, then put the RTV over top of it (pretty heavy amount) then let it dry for a few days. Went back and trimmed the gasket to the correct shape and put it in. Its been about 5-6 years and the taillight still water tight. It is for sure a time consuming way to go about it, but I didn't have any rubber laying around and they didn't make a gasket anymore.
1967 Chevy C20 to K20 Conversion "Simply Toxic" http://67-72chevytrucks.com/vboard/s...d.php?t=749409 1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775 |
03-14-2017, 01:27 PM | #7 | |
Posted via Mobile Device |
03-15-2017, 09:11 AM | #8 |
Active Member
Sounds like a plan, I'll try that, Thanks
03-15-2017, 11:34 AM | #9 |
All, I appreciate the replies. The foam ones I got will work....I just would like to have some OE style rubber ones. I like how they look and fit better. Seems they would be better all around....
