Old 03-14-2017, 07:32 AM   #1
riz
McGaughy Drop spindles and Wilwood calipers??
Can I use Wilwood Calipers on my McGaughys drop spindles on my 81 C10 ? I believe I have the 1" rotors up front.
RIZ
riz is offline   Reply With Quote
Old 03-14-2017, 08:10 AM   #2
homemade87
Re: McGaughy Drop spindles and Wilwood calipers??
Just curious why you want to go wilwood . Are you concerned about fitment or just want to upgrade to a 4 piston . I used all oem parts on my 2.5 spindle drop 1" rotors on my 82 . I did the oem rally's for a while ( they were close but worked ) until I got my 18" wheels .
If changing calipers you may also have to spend extra money on master cylinder to get proper pressure/pedal feel .
My guess would be they should fit . I would think they are a little more compact than the oem calipers .
homemade87 is offline   Reply With Quote
Old 03-14-2017, 08:20 AM   #3
riz
I'm doing a disc brake swap in the back and plan on using Wilwood calipers so I want the front to match plus I want a dual piston caliper. I have to get a new master, proportioning valve and stainless lines for disc brakes anyway.
RIZ
Old 03-15-2017, 01:52 PM   #4
riz
An answer to my own question..... yes, Wilwood calipers will work with McGaughys drop spindles from kit 93151 - 4.5 / 6 lowering kit.
RIZ
Old 03-17-2017, 12:28 AM   #5
UKNOWME
UKNOWME's Avatar
I have wilwood calipers and McGaughys spindles
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 03-17-2017, 05:34 AM   #6
riz
no issues?
RIZ
Old 03-17-2017, 08:39 PM   #7
UKNOWME
UKNOWME's Avatar
Originally Posted by riz View Post
no issues?
RIZ
None at all
1964 Chevy c10
