Old 03-14-2017, 10:49 AM   #1
snipescastle2
snipescastle2's Avatar
Question for all the differential Guru's.....
Hello everyone! Some of you may recall the 12 bolt differential I bought for my '71. It came out of a '64 C 10. The positraction unit is a rare bird, seems it was made by Dana, and it was only used in '64-'65, same differential as the Corvette, I know where it get the clutches/steels, but the problem with this diff. Is that it has 17 spline axles. Other than setting it up after replacing the bearings and seals, it's been pretty tight, I did however have the dreaded "ratcheting" noise associated with running without the posi additive ( I used the gear oil that supposedly had that blended in) got a bottle at the local GM dealer for $14 and no more noise.
Now, onto my question: I found another 12 bolt posi from a 65' C10 that is similar to the one I have out of the 64' but, this one has 30 spline axles. Does anyone know if the Eaton spider gears will interchange with the Dana ones? The reason I ask is, one of the side gears(splined ones) has the teeth damaged and needs replaced, I haven't tried to disassemble it yet, basically I can't find any documentation showing how it comes apart, it appears to require removal like an Eaton, but I'm not sure. I'd like to save this unit, but if I can't find the parts, might look to put it on EBay.
Anyone, anyone......
Thanks and have a great day!
Here are a few pics:
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 03-15-2017, 11:41 AM   #2
snipescastle2
Talking Re: Question for all the differential Guru's.....
Well, I got this carrier apart, turns out the clutches
were toast. I believe I have found a set of replacement
spider gears, and I found a set of clutches as well, if I can
confirm this spider gear set part number, I'll be in business.
If not, I'll put the parts on eBay or Craigslist I'm sure somebody
is looking for a part to fix their diff, since no one makes these parts
anymore. I'll post some pictures later if the "Carnage"
Have a great Day!
Ben
