Old 03-14-2017, 04:59 PM   #1
WarMonger
WarMonger's Avatar
disc brake bang for the buck
I'm getting ready to convert the the 70 to disc. It is 6 lug all the way around and want to know in your opinion, what is the best kit out there. ( not too expensive, but not cheap, easiest installation. what have you guys had good luck with? I have been looking at a classic performance kit.
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 03-14-2017, 05:08 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: disc brake bang for the buck
ECE by far the best kit, and superior customer service.
Talk to Mark at:
www.earlyclassic.com
These guys are truck guys, and have been doing it longer than anyone.
Research CPP for unhappy customers.
(Classic Performance Products)
Keith
Convert to disc brakes.
Old 03-14-2017, 05:12 PM   #3
WarMonger
WarMonger's Avatar
Talk to Mark at:
I was checking earlyclassic site, but I did not see the 6 lug for our year. I saw 5 lug. Maybe I will give them a call.
thanks
1970 C20
-_--_--_- ______
1972 K5
Old 03-14-2017, 05:16 PM   #4
randy500
You can buy all off the shelf parts yourself without a kit.
I wonder if it is cheaper that way.
I see you cut that one down into a short bed, if you haven't done so yet, remove the middle bed holes in the rail and the pocket underneath, dead giveaway it was cut down...
randy500 is offline   Reply With Quote
Old 03-14-2017, 05:18 PM   #5
WarMonger
WarMonger's Avatar
thanks Randy for the info. I have not removed the middle holes. I dont mind it being a conversion. I will keep all the weld lines showing.
1970 C20
-_--_--_- ______
1972 K5
Old 03-14-2017, 05:25 PM   #6
randy500
I don't see anything wrong with cutting the bedsides down, I love the shorty's, I see a lot of people commenting on those middle stake pockets...and most that I see cut down they forget to remove those.
Old 03-14-2017, 05:35 PM   #7
randy500
Let me ask you this, why are you changing to disc brakes? It wont stop any better than a properly serviced drum brake setup. Discs are better on successive stops because of heat and the drum expanding. You could save a lot of money by not converting and being happy with the drums...
Old 03-14-2017, 05:54 PM   #8
custom10nut
custom10nut's Avatar
SSBC has a kit on Amazon that doesn't require you change spindles or balljoints. I want to say it's coming through Summit, but backed by Amazon for customer service. And the shipping is included. They also have the complete kits with drop spindles, new hubs, and the whole shebang, for more money of course.
I'm looking at ordering my kit in a couple months, but I want to redo my bed wood first.
custom10nut is offline   Reply With Quote
Old 03-14-2017, 06:26 PM   #9
WarMonger
WarMonger's Avatar
Converting because I want to go lower. So I was thinking drop spindles. Or should I just go airbags and leave drum brakes?
1970 C20
-_--_--_- ______
1972 K5
Old 03-14-2017, 06:37 PM   #10
custom10nut
You'll be able to go lower with drop spindles, so if you're going that rout, go ahead and convert it to disc. Keep in mind that some kits aren't compatable with stock wheels, so make sure before you buy.
Old 03-14-2017, 06:40 PM   #11
Grumpy old man
Grumpy old man's Avatar
Always call Pirate jacks for any brake questions
http://piratejack.net/
Grumpy old man is offline   Reply With Quote
Old 03-14-2017, 08:22 PM   #12
GR8-68
GR8-68's Avatar
I would not use SSBC, my boss bought those for his square body and I was not at all impressed with the quality. I bought all wilwood for mine, great quality and fitment for a decent price
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 03-15-2017, 01:36 AM   #13
mosel70
I did mine last summer, put on CPP's 6-lug disc kit, standard rotors/lines, love it. Installed power brakes at same time along with CPP's tubular upper/lower control arms since I had everything apart. Brakes really nice now. 1970 C10 SS w/402
mosel70 is offline   Reply With Quote
Old 03-15-2017, 01:43 AM   #14
mosel70
Let me add I used CPP's 6370SWBK-6D with 2 1/2" drop spindles
Old 03-15-2017, 10:06 AM   #15
davepl
davepl's Avatar
Why not factory discs off a later unit? GM made millions of them and they've been thoroughly tested. There's no drop version of them, of course, if that's a requirement.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-15-2017, 10:26 AM   #16
randy500
Aren't all of those kits the exact same GM parts just sold in kit form? Except willwood I think they are just GM parts.
Like I said I would price out collecting all the parts from summit (free shipping) or rock auto. You do need a set of brake lines though and for those you better have some good pictures of how they install in every area of the frame and crossmember or it will be a problem, I have read the kits are very weak in that respect and its really the hardest part of the whole job.
Old 03-15-2017, 10:26 AM   #17
randy500
By hardest part I mean time consuming, confusing and easiest to screw up.
