firewall pad insulation glue
does anyone what kind of glue that black tar like stuff was used by gm to glue the firewall pad on the interior firewall? i want to used that same type of glue/caulk on some other things. thanks
Re: firewall pad insulation glue
the firewall pad is held to the interior (cab side) of the firewall with rubber plugs, not glue.
the pad itself is held in by plugs but the upper part insulation on mine was glued in from gm
![]() Join Date: Mar 2003
Ahh, I think you are referring to the part that moves up under the upper dash by the speaker. I think GM just used a high contact cement
yes , its all in the upper part of the dash, what type of glue could this be , it was some sort of black tar, not so much a contact cement but like a splatter of caulk
I have no idea, but I know it takes almost a blow torch to get the stuff off
![]() Join Date: Jul 2016
I think that was just contact adhesive that was sprayed on, years ago that stuff was not black it was yellow on the ones I removed long ago.
#8 | |
![]() Join Date: Feb 2009
Here's one on the driver's side: ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
thats it, you got it ., is the black tar like glue just contact cement? or something else?
#10 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-15-2017 at 11:56 PM. |
#11 | ||
![]() Join Date: Feb 2002
The black tar was in the jute to hold it together and be water resistant. [Old tech.] They still used adhesives -- either 3M Weatherstrip Adhesive ["Supersnot''], or 3M 77 Contact Spray Adhesive.
In hot climates [like Tucson] the tar would melt in to the floor and firewall. I had to use a lot of turpentine and rags to get it up.
#13 | |
#14 | |
#15 | |
I wasn't there when they built your truck. Could be different years and different plants may have had varying procedures. What year and what plant produced your truck? You have a '66 or earlier in your avatar.
