Old 03-15-2017, 11:33 AM   #1
PowerdbyChevy79
PowerdbyChevy79's Avatar
dash swap
question... will a 73-80 dash fit on a 82 .. really like the gauge and dash setup on the 73-80..
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 03-15-2017, 12:58 PM   #2
TKCR
TKCR's Avatar
Re: dash swap
Yes it will, but you'll have to use the bezel and trim for that dash.
Mounting should be the same. But I do believe the bezels are specific to the year group.
The pads are 73-78, 79-80, 81-87
The bezels are 73-80, 81-83, 84-87
Old 03-15-2017, 01:30 PM   #3
75C10
Re: dash swap
The early gauges with the ammeter are not going to work easily. Direct replacement will likely let the smoke out of your wiring. Later 70's gauges with the voltmeter will work but you will have to be sure the pin outs are correct. Do your home work.
75C10 is offline   Reply With Quote
Old 03-15-2017, 04:08 PM   #4
PowerdbyChevy79
Re: dash swap
I'm going with Dakota digital so I shouldn't run into the ammeter issue..but thx for the heads up
really dig the older style dashes...
1966 C10 "Mary"
