03-16-2017, 08:22 AM | #1 |
Gas filler neck box
When I finished my truck, I tried to put gas in it at the station. It would not take it. I tried several different flush mount "necks" before I had to go to the taller one. So I made a box to kinda hide it. I don't really like it, but have no other choice. You guys are experts. How bad does it really look? Be honest.
03-16-2017, 08:26 AM | #2 |
The Older Generation
Re: Gas filler neck box
I think it looks good. Are the chrome pieces hold downs or handles? Do you have the vent tube hooked up? LockDoc
03-16-2017, 08:48 AM | #3 |
Look like little hinges so the lid just rotates up? Looks fine, nice job.
03-16-2017, 09:08 AM | #4 |
Correct Jocko, those are stainless hinges.
It has 2 vents on it. One was not enough. |
03-16-2017, 09:26 AM | #5 | ||
LockDoc
03-16-2017, 11:17 AM | #6 |
looks like it fits real nice. How's it attached to the rest of the truck, welded in, anchors, epoxy? If it's sealed tight might want to add a drain hole of sorts inside the box in the bed floor in case anything leaks past it going down the road, rain, spilled gas, etc.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
03-16-2017, 11:33 AM | #7 | ||
"I ain't nobody, dork."
I also think it looks pretty damn nice! Good job!
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
03-16-2017, 12:10 PM | #8 |
It is held in with 4 stainless screws, 2 in wheel tub & 2 in bottom. I welded tabs on it. Will not hold water, no drain needed.
03-16-2017, 01:26 PM | #9 |
Nice work! Don't see any problem with it at all. Could even use it as a secret stash!
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
03-16-2017, 01:26 PM | #10 | |
Sweet deal, good job!
03-16-2017, 01:55 PM | #11 |
That looks great. What fill neck is that, I have the exact same problem.
03-16-2017, 04:09 PM | #12 |
Neck is off a Harley tank welded to 1 1/2" exhaust tubing.
03-16-2017, 07:35 PM | #13 |
I thought it was a panel/suburban neck, looks just like the one in my '67 panel....
LockDoc
03-17-2017, 12:40 AM | #14 |
looks great, you could even add a hasp/lock if you needed too.... what kind of liner did you use on your bed?
03-17-2017, 01:08 AM | #15 |
X2 on looking good. Good workmanship. ..
03-17-2017, 05:47 AM | #16 |
Jim, Bed liner is Duplicolor clear mixed 8 to 1 with paint. Sprayed on. 2 coats. Bought at Jegs.
03-17-2017, 06:18 PM | #17 |
That looks great! Looks like it belongs there. High enough to make it easy to fill, yet small enough that people won't stare at it and ask "what the heck is that?"
It's much better than my Redneck version...
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten. |
