Old 03-16-2017, 12:36 PM   #1
Janz99
LS/4L80E swap mounts.
Hi guys, I am in the middle of acquiring all the parts I need to do an LS/4L80E swap in my 68. I am having a hard time deciding which mounts to go with and was hoping a few guys that have used some of these, will chime in with their experience with them.
The ones I've looked at so far are:
Early Classics Gen3 mounting kit: $219
Early Classics 4L80E cross member: $89
Dirty Dingo slider mounts: $162 (with new engine side mount)
http://www.dirtydingo.com/shop/index.php?cPath=359_360
DD doesnt seem to offer a trans cross member at this time.
Has anyone used either of these? How did you like them? Is there any other companies offering swap mounts/cross member for this combination that I have missed?
Any suggestions would be greatly appreciated.
Janz99 is offline   Reply With Quote
Old 03-16-2017, 01:00 PM   #2
davepl
davepl's Avatar
Re: LS/4L80E swap mounts.
I haven't done an LS/4L80E swap, but I've done them individually (4L80E into my truck, LS3 into my Camaro) and in neither case did I need to change the rear crossmember.
In fact I just used el-cheapo eBay LS engine mount adapters and everything worked out fine for me, but you might be facing different challenges.
Short version is don't rush out to replace the crossmember until you're confident you really need to.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-16-2017, 01:07 PM   #3
Janz99
What trans mount did you end up using? Did you need to do any modifications to the stock cross memeber to get the 4l80E to bolt up?
Do you happen to have a link to what engine mounts you used? I would prefer not to use solid engine mounts, so I was looking into kits that use some sort of stock v8 engine mount and a conversion plate to adapt it to the LS.
This is my first "vintage" vehicle, so this is all a learning experience for me
Old 03-16-2017, 06:27 PM   #4
Willie Makeit
Willie Makeit's Avatar
running a 5.3 on stock towers and DD sliders hooked to a 4L80e and it's sitting on a CPP crossmember. not expensive and works like a charm
Willie Makeit is offline   Reply With Quote
Old 03-16-2017, 07:17 PM   #5
chevy72blu
chevy72blu's Avatar
I used the CPP engine mounts and towers. They clear headers really well and look nice.
Stock crossmember, just relocated. I did need to shorted my driveshaft.
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 03-17-2017, 11:57 PM   #6
jweb
jweb's Avatar
I have seen several builds that use stock mounts with the ICT adapters.
http://www.ictbillet.com/engine-swap...plate-ls1.html
jweb is offline   Reply With Quote
Old 03-18-2017, 10:25 AM   #7
72MARIO
72MARIO's Avatar
I used the DD sliders in my 68 suburban slid the engine and transmission around till the stock transmission crossmember lined up with factory holes.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 03-18-2017, 12:36 PM   #8
davepl
davepl's Avatar
It's been a while but if I remember correctly I used my TH400 mount but turned it around backwards. Don't take that to the bank, but that's how I remember it... Stock crossmember in stock location.
Old 03-18-2017, 09:52 PM   #9
Janz99
Thanks guys for all the suggestions. I just purchased an 84 parts truck that I am planning on swapping the front cross member, disc brakes and sway bar from. What would be needed to adapt the LS to the new 84 cross member?
Old 03-18-2017, 10:20 PM   #10
stexag
I'm going to start this same process in just a few days when my dropout LS gets here. Therefore....
stexag is offline   Reply With Quote
Old 03-19-2017, 05:57 PM   #11
solidaxel
solidaxel's Avatar
Same for me with my 78 and a 4L60E, I moved the trans back to fit the stock driveshaft and trans linkage.
Did have to re locate the x-member to the rear
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-20-2017, 10:59 PM   #12
Liltroy
Liltroy's Avatar
i used $25 ebay mounts and modified my crossmember for the 4l80. its all in my build thread
74 Stepside"Steppin Wolf":78mm Turbo LQ4/4L80e,BTR stage 3 Truck cam,3.73 12 bolt with Detroit True-Trac
Project Steppin Wolf Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=670303
My Youtube channel "Bad Luck Garage" https://www.youtube.com/channel/UCRP...XkeEPCu_HmRfuw
Liltroy is offline   Reply With Quote
