03-16-2017, 04:13 PM | #1 |
Need help finding the correct starter
I'm about to drop in a 400 SBC w/ 168 tooth flex plate. I've read about someone recommending using a high torque starter for 69-70 Corvettes (LT1), but haven't been able to find that. Just looking for a good high torque mini starter that for sure will work for my 400 SBC, just want to do it right the first time around. Any info is appreciated, thanks!
03-16-2017, 05:22 PM | #2 |
Re: Need help finding the correct starter
Go the parts store and look at a starter, the factory high torque motor has the motor terminal almost at the end of the motor and uses a thin copper tube spacer between the connection and the solenoid. If the motor terminal attaches directly to the solenoid its not the HD version.
03-17-2017, 12:17 AM | #3 |
yeah, you don't need the mini starter, like Randy 500 said, just get the hd starter with the longer terminal
03-17-2017, 10:51 AM | #4 |
I would go opposite. Yes, the longer starters are higher torque but they are still only good for so long. Get a factory mini-starter for a '95 Suburban.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
03-17-2017, 12:01 PM | #5 |
yep the 95 suburban starter is way better, and you can get one anywhere if it craps out on a road trip.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
03-17-2017, 08:56 PM | #6 |
Thanks guys I really appreciate the help
