5.3l swap popping
I recently i swapped my old 350 for a 5.3l LS. Took me months to do this. A few weekends ago it was time to turn the key to see what i had. And when i finally got the nerve to do so, my motor just pops back through the intake. I put my scanner on it and it gave me a code for "crankshaft sensor". Replaced it and still did the same thing. Can anyone out the there tell me what the problem is?
Re: 5.3l swap popping
Welcome to the site. I've never done an LS swap and not real big on computer controlled servicing, but it sounds like one component isn't talking to the other. Something is either not connected properly, wiring issue, other bad component. There is an LS swap message board where I'm sure you'll find your best answers.
What did you do with that Olds 350?
#3 | |
If you replaced the sensor and it didn't help, trace the wires carefully to make sure they didn't get knicked/cut/pinched/etc somewhere.
I don't remember the details but I seem to recall having to do some type of "crank relearn"
Try searching for that. |
Does the engine turn over smoothly when cranking, besides the popping of course
![]() Join Date: Jan 2012
Double check your coil pack harness. Sounds like you may one or both backwards.
passenger side from front back 2 - pink/red/brown/black 4 - pink/green 6 - pink/blue 8 - pink/purple driver side from front to back 1- pink/purple 3 - pink/blue 5 - pink/green 7 - pink/red
Cheers - Wayne Our Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=620966 '55 Wagon Build - http://67-72chevytrucks.com/vboard/s...d.php?t=689157 1971 Cheyenne Super Ochre/White LWB 350 Auto - my son's truck "Nancy" 1972 GMC K2500 Custom 4X4 Olive LWB 400 SB 4-speed -"Greenie" - Restoration to begin after the '55 Nothing sucks more than that moment during an argument when you realize you're wrong. |
#8 | |
meowMEOWmeowMEOW
Did you do any internal engine work, or is this a stock pullout?
If you end up chasing a solution, you may consider a CASE relearn. This is what was being alluded to earlier. When you put a new crank sensor in, the ECM may need this done. It basically recalibrates the sensor and ECM to the crank angle sensor, and its relationship/phase with the cam sensors. If you did a cam swap, its also very possible. The downside is that CASE relearns require command-access to the the ECM, so thats something like HPT, a TechII/III or other full feature scanner/control.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
But doesn't a crank sensor alignment (or CASE, whatever) require the engine be running before they do it? So it can't be the cause of a no-run, if that's the case...
Given this sounds so much like a distributor issue (and there's no distributor) I'm leaning towards the coil pack myself as others said... we shall see what the owner says!
![]() Join Date: May 2015
I'm with daddyo..when I got my engine running it had a backfire/miss to it and a couple of cold header tubes on the drivers side..I looked at the coil pack harness and it looked ok..but I also went and looked at my new trucks harness and sure enough the coil packs were wired backwards..simple swap and it ran like a charm..
#12 | |
Get the coil packs wrong and all bets are off though!
#13 |
Dogonit..your right ..I meant coil packs..sorry..I fixed my above post..thanks for pointing it out
#14 | |
meowMEOWmeowMEOW
#15 |
Sorry fella long weekend. The truck is at the shop right now getting exhaust done on it right now. I will go through it this week and let you guys know what i found. And thanks for all the comments.
#16 |
#17 | |
#18 |
Did you service, clean the injectors, if it was sitting for a long time.
How is the fuel pressure?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#19 |
if it sounds like it wants to start but is popping, I would double check that the map sensor is reading correctly. I had an issue similar to yours, and it turned out to be the map sensor always reading 100kpa
#20 |
Guys i just want to thank you all for your help. I had the coil harness on the wrong sides. Lol she is definitely running now.
#21 | |
meowMEOWmeowMEOW
#22 |
glad ya got it fixed..
| Bookmarks |
| Tags |
| 85 k5 blazer 5.3l 700r4 |
