Old 03-17-2017, 09:28 AM   #1
everetteladner
Testing the fuel sending unit
Hi, I need advice about my sending unit. It is a new unit that I tested before installing. It shows 30 ohms at full and near zero at empty. I installed the new sending unit and tested it before hooking up the wires. Meter shows 2.9 with a verified full tank. I took out the sending unit and tested again, works correctly. I reinstalled the unit and again it shows a very low ohm at full tank. When I reinstalled the unit, I made sure the float was moving freely and not leaking. Any ideas? Thank you
everetteladner is offline   Reply With Quote
Old 03-17-2017, 09:37 AM   #2
everetteladner
Re: Testing the fuel sending unit
My truck is a 1966 C30, 250 6
Old 03-17-2017, 08:12 PM   #3
luvbowties
luvbowties's Avatar
Question Re: Testing the fuel sending unit
R u sure swing-arm is installed correctly & not hitting a side or end of tank? Also, what does meter read WHEN INSTALLED with an empty tank???
s
luvbowties is offline   Reply With Quote
