High Oil Pressure
Hey guys, I just put in new gauges on my 72 and am reading 100psi oil pressure on startup and eventually after a drive itll come down to 75. I plan on buying one of those cheap oil pressure gauges with an oil line to confirm the reading from my new gauges, but is there anything else that might be wrong? Engine is a rebuilt sbc off CL. Runs well but I have no idea what went into it. It does have an oil leak somewhere towards the rear of the engine on the drivers side. haven't figured out if its the valve covers or what
![]() Join Date: Jun 2014
Re: High Oil Pressure
Do you know the history of your engine? Maybe you have a high volume/high pressure pump in there? Or did this just start after being "normal"? Did you do a recent oil change and put a heavier weight oil in? The stock oil pressure gauges don't read in PSI so is this an aftermarket gauge you just put in? Give us more info and we'll try to help you out.
B/R, Randy |
#3 | |
http://newvintageusallc.mybigcommerc...y-truck-retro/ |
Obviously, the easiest and cheapest thing to do is to get another oil pressure gauge, a mechanical type of known quality, and plumb it into the engine and compare the readings.
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
If this is a Big Block, you will wipe out your cam and valve train eventually. Not to mention the increased pressure is robbing you of free horsepower.
http://www.jalopyjournal.com/forum/t...please.627788/
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#6 | ||
Not sure why Demian says the big block oiling is much different than the small block, I'd be curious.
Your biggest risk is likely an exploded oil filter if you rev it up cold. But I'd want to confirm those readings with another gauge if possible before you got too concerned about it. If the pressures are indeed high, your other risk is that most of your oil will be bypassing the filter. I would guess this stems from bearing clearances and rod-side-clearance, but it must be very tight if the gauge is right!
