Old 03-17-2017, 04:42 PM   #1
DT1
DT1's Avatar
Still Can't Find the Right Gas Cap
I could really use some help here. I have a 72 C10 with a vapor recovery system that needs a gas cap. The filler neck is smaller diameter than the one on my 71 C10. I ordered an "OEM" cap from Rock Auto for the 72 (Stant 10742 deep cam) It fit the filler neck but it wouldn't tighten. It was so loose a good gust would blow it off. So, I ordered an "OEM" for a 71. Stant 10704 shallow cam. it was too large in diameter to even go into the filler neck but it fit on the 71 just right. I looks like I need a cap like the Stant 10742 but not a deep cam type. A shallow cam type might work. Does anyone know what I really need??
DT1 is offline   Reply With Quote
Old 03-18-2017, 12:13 AM   #2
El Dorado Jim
Re: Still Can't Find the Right Gas Cap
have you checked your local auto parts stores? they may have the right one...
El Dorado Jim is offline   Reply With Quote
Old 03-18-2017, 12:32 AM   #3
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
By chance do you know if a vented cap fits? I assume you're looking for un-vented.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 03-18-2017, 07:44 PM   #4
DT1
DT1's Avatar
I need an un-vented one. I've been looking for almost a month. All I really need is a part number for a cap with a 1 3/8 filler neck and it must be a shallow cam type.
The auto parts houses are useless.
It's so ironic. Total restoration and I'm slipped up on a ^&(*ing gas cap!!
