Old 03-17-2017, 05:21 PM   #1
mgb
mgb's Avatar
Too close to the steering wheel
I've put different seats in my '68 and I can't get far enough away from the steering wheel. I don't need a whole lot, but I need a little room. What are my choices?
mgb is offline   Reply With Quote
Old 03-17-2017, 05:28 PM   #2
Ben_Yeaton
Re: Too close to the steering wheel
You can shorten the column by collapsing the sleeve in the lower portion near the rag joint. I recently did mine 2" and it makes a world of difference to me. You can find good info in these threads:
http://67-72chevytrucks.com/vboard/s...d.php?t=191143
http://67-72chevytrucks.com/vboard/s...d.php?t=309895
http://67-72chevytrucks.com/vboard/s...olumn+collapse
Ben_Yeaton is offline   Reply With Quote
Old 03-17-2017, 11:18 PM   #3
fatbass
fatbass's Avatar
Thanks, Ben! I may be be using that trick after I get the steering wheel swapped.
fatbass is offline   Reply With Quote
Old 03-18-2017, 12:12 PM   #4
davepl
davepl's Avatar
I found Tilt helped a great deal, but I was just trying to get the wheel out of may lap, not out of my belly, so I don't know if tipping up and away would benefit you. But it might, and it's a pretty easy thing to find and add.
Worth trying it in someone else's tilt truck if you can.
The column shortening looks perfect, but I worry a bit that you're losing what razor-thin safety margin we have in a crash in these trucks by defeating the collapsing column. Might be better combined with three point belts!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-18-2017, 01:40 PM   #5
saxart
saxart's Avatar
How is this defeating the collapsing column? I take it that this mod is collapsing the column some but not all of it's travel.
Maybe someone who's done it can chime in as to how much travel would be left after this mod.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 03-18-2017, 03:48 PM   #6
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Anyone who thinks there is a safety issue with collapsing the lower shaft on the steering column should make sure their life insurance is paid up if they are in a head-on collision. Depending solely on the lower shaft to keep them out of the hospital or morgue you will quickly find out what a marvel of engineering it was.
CaptRMW is offline   Reply With Quote
Old 03-18-2017, 08:53 PM   #7
mgb
mgb's Avatar
Thanks Ben, I did collapse the column today, a little over (2) inches, and it's exactly what I was looking for. A relatively easy fix, I did use a lot of heat just like the link said - till the plastic oozed out. If you did go much lower, you might want to think about a tilt wheel because she does start getting pretty low. But then again, the seats I'm installing set a little high. Thanks again guys, I would have never thought of this.
Old 03-18-2017, 09:01 PM   #8
leddzepp
Moderator
leddzepp's Avatar
It's done when installing a van tilt column as well.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 03-19-2017, 08:56 AM   #9
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Now that you have collapsed your column can you imagine doing that with your chest in a head on collision and being able to walk away?
