Old 03-17-2017, 10:44 PM   #1
mosel70
'70 ECS Fuel Tank Vent Question (filler neck)
I have a 1970 C10 with ECS fuel tank. I'm hooking up the entire ECS system to include canister and vacuum lines.
At the filler neck I have a vent line. There is another vent line on the top drivers side of the tank and a third vent line on the driver's side cab wall that goes up and over to the passenger side. The two attachments show different connection methods.
Q. Should the vent line from the filler neck to the tank top vent line (drivers side) be T'd off to connect also to the vent line that goes up and over?
mosel70 is offline   Reply With Quote
Old 03-18-2017, 11:34 PM   #2
mosel70
Re: '70 ECS Fuel Tank Vent Question (filler neck)
So I capped off the small metal filler neck vent tube (inside drivers side) and connected drivers side vent with tube going up and over to passenger side. All ECS components connected, returned Edelbrock 750 carb, runs great and finally no gas fumes in the truck or garage. Used non-vent gas cap as required. Went through three gas caps to finally find one that fits and doesn't leak when tank is full (Amazon, Stant 10704 Fuel Cap).
