Motor not heating up...
I need some help! My sbc 355 is not warming up. I am getting limited heat as well. I have replace the tstat. I have also noticed that when I drive for several miles, pull over, I can take off the radiator cap(which i replaced) with little to no pressure built up. One side of my radiator is HOT and the other side is only warm to the touch.
I have racked my brain over this. What do yall think???? |
Re: Motor not heating up...
How do you know the engine is not heating up? Have you used a thermometer to measure the coolant temp, or a remote temp sensor to "shoot" the area around the T'stat housing?
Sounds like you have a coolant circulation issue, or a bad heater core if not much heat from the heater. Could be an airlock (some air left in the cooling system). I would wait till the engine is stone cold, start it, lift the hood, and feel the top rad hose to see if it warms up, but only after the engine gets warm. So there's a few ideas for ya.
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
if you have already replaced the thermostat, I have no idea what could cause this....but I hope someone can help, I am very interested in why it's not warming up
Mine did this and my heater core was shot.
1967 Chevy Truck 1969 Chevy Panel Truck work in progress 1971 GMC 1500 all orginal 1972 Chevy Suburban brought from orignal owner 1984 Dodge Rampage 45,000 original miles 1992 Dodge D150 1994 Buick Roadmaster (LT1 Engine) 2000 Chevy Stepside Z71 2008 Honda Element |
laying low
![]() Join Date: Mar 2001
What temp stat you have makes a difference in how much heat it builds. A 180* stat should build plenty of heat. It sounds like the radiator and fan are doing their job just fine. Once you start your engine cold feel each of the heater hoses while it warms up as one will get hotter going to the heater core and the other will be slightly less hot coming out. If one heater hose stays noticeably cooler than the other that's a good indication the heater core is plugged. If so you can remove the hoses at the heater core and back flush it with a garden hose and maybe get more circulation through it but it really will need to be replaced. The lack of pressure in the radiator can be a leak in the system or a bad radiator cap. A 13# cap is about normal.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
If your T-stat is opening then either your motor is magically not making heat or its not getting to where you're looking - like the heater core.
But if it's not making it elsewhere, maybe the pump is shot? I think you need a thermal gun to record a bunch of measurements at the heater core outlet and return, radiator outlet and return, and so on, looking for anomalies. The heat is going somewhere!
Water pump failure will cause this as well.
or a reverse flow water pump
Thanks for all of the replies! I dont know what i would do if I didnt have forums like this to go to. LOL. I will be taking a closer look at the core tomorrow to see what i find.
