Old 03-18-2017, 04:29 PM   #1
Adam4pt6
Another brake swap question, hopefully a pretty simple one though
So 1st off, thanks for dealing with my **** ton of questions.
I have a 69 c20, and I'm looking to swap to power discs in the front and lower it.
Right now I have: stock 1969 c20. And I have rotors, calipers,and tierods (in, out and coupler) from a 1982 8 lug suburban.
In ordeer to make it all work I would need (drop)spindles for the 82 suburban, upper and lower ball joints for the suburban (I can reuse my a arms correct?). And a booster, master cylinder and proportioning valve off of a 71/72 c10.
Is all of that correct? I'm about to order the rest of the parts and just want to be sure before buying all of it.
Thanks again
Adam4pt6 is offline   Reply With Quote
Old 03-18-2017, 04:50 PM   #2
wbc409
Re: Another brake swap question, hopefully a pretty simple one though
I believe you need to use the A-arm's from the 82 also. You need to check the size of the ball joints out. The size and taper could be different.
wbc409 is offline   Reply With Quote
Old 03-18-2017, 04:52 PM   #3
Adam4pt6
Damn, ok. I was under the impression that I could put the "newer" ball joints in my a arms. Looks like I'm going back to the junk yard lol
Old 03-19-2017, 12:53 AM   #4
randy500
The newer ball joints should fit the older control arms.
randy500 is offline   Reply With Quote
