![]() Join Date: Nov 2006
exhaust thry x-member question
hey when you fellas run your exhaust pipes thru the x member how are you,all doing it. pic,s would be super.
thanks
I BELIEVE IN JOHN 3:16 |
![]() Join Date: Oct 2004
Re: exhaust thry x-member question
Here is a picture of my exhaust going through the center cross member on my 69 Suburban.
Steven 69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners ![]() 2017 50th Anniversary Camaro SS 2004 Chevy Impala LS 2016 Chevy Malibu LT |
WHAT size holes did you cut and did yoy plate the crossmember . I,am gonna run 2 1/4 pipes
I had an exhaust shop build my exhaust. I'm running a 2.5" exhaust so I believe the holes are around 3" in diameter. The X-member is not strengthened where the holes are cut.
72 BB C30 Super LongHorn
![]() Join Date: Nov 2002
Sorry to hijack your thread but what sway bar are you using here in this ?
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS ![]() |
stock sway barbut I have a adjustable one ready to go in
![]() Join Date: Oct 2014
Here's a couple of pics of my cross member through holes. I used 4 1/2" tube by 1 1/2" wide and 3/16" thick. I picked up the tube from a fab shop down the road from me.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
super rudy thanks. did you also flip the truck arm mounts
Yes I did flip the truck arm mounts but I changed them back because I thought there was too much pinion angle when I got the suspension loaded to ride height.
RUDY, how much did you drop the rear suspension. mine is 6-7 lowered lwb and is hard on carrier bearings
These look great. We have an LS and that exhaust gets really hot... we also have air ride with nylon lines. Real hot + nylon lines = sudden leaks. If your plans include anything plastic/ melty in the area consider heat wrap or insulation/ heat shields.
71 C-20 Custom Camper California Truck |
no plastic on my truck
#13 |
My 68 has a 5 1/2-7" drop but I have a one piece drive shaft.
#14 |
rudy, is your truck lwb
#15 |
No, short wheel base
#16 |
