Old 03-18-2017, 11:33 PM   #1
Rayn9055
1977 k10 suburban
My suburban is a all time 4wd I went to start it and let it warm up and I shifted it Into neutral to let all fluid to cycle and my vehicle warm up after a bit I went to shift into into reverse and then I started to free roll forward and no gears will engage. Every time I try engage gear it whines and after about 30 seconds stops whining and whines in any gear I try to shift into and all gears stopped working at same time the transmission is a th350 fluid is at right level a little dark red color and and looking for ways to troubleshoot my problem I am am planning on changing fluid and filter and was wondering what all else I can try to see if is a easy fix or not that may get it driving again. Any help please????
Rayn9055 is offline   Reply With Quote
Old 03-19-2017, 06:45 AM   #2
Edahall
Re: 1977 k10 suburban
Make sure your transfer case is not in neutral.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 03-19-2017, 08:24 PM   #3
Rayn9055
Thank you for the I found out that was the problem.
