Old 03-19-2017, 11:33 AM   #1
timberjim36
timberjim36's Avatar
power window hook up
I just picked up a set of power doors for my 80 V30 and im trying to figure out how to get the wiring hooked up at the fuse box anybody have any pics or guidance
1980 crewcab dually soon to have a gen VI 454 rectangular port heads holley strip dominator crusader marine stand alone tbi setup with a TCI tcu controlled 4L80 (daily driver)
92 harley electra glide ultra classic
timberjim36 is offline   Reply With Quote
Old 03-19-2017, 11:34 AM   #2
gmachinz
Re: power window hook up
What year are your doors?
gmachinz is offline   Reply With Quote
Old 03-19-2017, 12:07 PM   #3
timberjim36
I belive theyre 85
Old 03-19-2017, 12:37 PM   #4
gmachinz
Well...77-80 is one style and 81-up is another. You need a new style harness since those are newer doors. The fuse panel only requires an IGN source and Battery source. Window circuit will also need a chassis ground underdash. So, if you want to save a little $$$, you need to pull a complete harness from an 81-up Suburban or crewcab-then install it all as-is into your truck. If you don't have power in it now, you need to drill for cab-door grommets too-both inside and outside. I can supply you with a complete hybridbharness just for your application for a clean stock appearance but otherwise you'll need to source it all from a newer truck....trust me those are your two options.
Old 03-19-2017, 12:49 PM   #5
timberjim36
Ok thanks thats what i had kinda figured heading to the bone yard tomorrow so ill look aeound
Old 03-19-2017, 01:00 PM   #6
gmachinz
If you are going to a junkyard, hit up the older GM stuff w/power windows and look for the glass fuse block style blue and red connectors-you'll need those for IGN power and Battery power.
