Old 03-19-2017, 03:56 PM   #1
GR8-68
GR8-68's Avatar
Vent door?
Does anyone know if this vent door is even available at all anywhere or if the seal can be repaired or replaced ?
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 03-19-2017, 04:46 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Vent door?
I hear the seals are available.............or you can buy new vent doors. As I recall, other than the originals being painted, there's no difference between the original doors what I purchased from Classic Heartbeat.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 03-19-2017, 05:02 PM   #3
Barbara Jean
Barbara Jean's Avatar
Re: Vent door?
My daughter sent for this catalog for my truck.I have a 1967 Chevy.The same vents that you have.Here is the catalog to send for "1960-1972 Chevrolet-GMC Truck. http://www.truckandcarshop.com/
On page 51 is the pr of fresh air vent valve seals at $7.00 pr.67-72.Part #67-05313.
Barbara Jean
Barbara Jean is offline   Reply With Quote
Old 03-19-2017, 06:59 PM   #4
GR8-68
GR8-68's Avatar
Re: Vent door?
I found them in the catalog for classic industries, 5.99 for the pair. I assume you have to drill the rivets out as the seal is sandwiched between the two pieces. Has anyone ever replaced these seals ?
Larry
"Project 68"
paypal.me/ldgrant
Old 03-19-2017, 07:03 PM   #5
GR8-68
GR8-68's Avatar
Re: Vent door?
http://www.classicindustries.com/pro...rts/iv672.html
Seals for 5.99 or
http://www.classicindustries.com/pro...rts/14839.html
They do have the complete unit for 44.99
Larry
"Project 68"
paypal.me/ldgrant
Old 03-19-2017, 09:26 PM   #6
master 1969 c10
Active Member
Re: Vent door?
Don't sweat this I just did it with mine it's easy all you had to do is drill out the rivets get your new seals and aline the seal free pre drill the rivet holes through the seal. Just do one at a time and now is the time to clean them up and paint. Doug
master 1969 c10 is offline   Reply With Quote
Old 03-20-2017, 06:24 AM   #7
GR8-68
GR8-68's Avatar
Re: Vent door?
So did you rivet them back together ?
Larry
"Project 68"
paypal.me/ldgrant
Old 03-20-2017, 01:55 PM   #8
67ChevroletDude
67ChevroletDude's Avatar
Re: Vent door?
I took mine apart, just drill out the rivets, and while you're at it you could clean them up and paint them. It's a very easy thing to do. I pop riveted mine back together since they are out of the way.
67ChevroletDude is offline   Reply With Quote
Old 03-20-2017, 02:18 PM   #9
BILT4ME
Re: Vent door?
I did mine years ago and used some 1/8" thick red silicone gasket material that was soft and pliable.
I drilled out the rivets and replaced them with screws and nylock nuts. I used the old gaskets to get close on the cutout for the gasket material. It was more about time than cost. The cost was like $15 for the material, then I had to cut out the patterns and drill the rivets and bolt it all back together. Probably a couple hours for both, taking my time.
1970 GMC K2500
Dis-use is harder on a car than mis-use.
BILT4ME is offline   Reply With Quote
