Old 10-17-2003, 11:27 PM   #1
Tom
driving is in my blood
Tom's Avatar
Does this fuse affect the vehicle?
Hey guys, I had some electrical problems the other week, found out it was one of the in-line fuses from the starter. There are two fuses down there, one that has one line in/ one line out. The other has one line in/ two lines out. My busted fuse was the double line one. I removed the fuse and connected all three wires together with an electrical....ummm well ok I have no idea what its called but its the connecter thingy that screws over the wires. Anyways I put them together and preto truck is good. Now truck is horrible and wont run and my plugs are wet which makes me think I screwed up my ignition by removing that fuse? Any other ideas? I posted my saga of problems in the drivetrain forum.
Old 10-18-2003, 12:16 AM   #2
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Dude!,
Are you saying you used a household wire nut that looks like a milk shake cup for a barbie doll??
If so you gotta get that thing off of there like right now!
If it comes off you could have a fire on your hands cuz you have no protection i.e. no more fuseable link.
The next thing you need to do is find out why the fuseable link blew in the first place they don't just go bad! and correct the problem. Could be a bad starter solinoid or the starter windings.
Then get another fuseable link and some compression crimp type wire connectors and install it like the original was.
This could cause a poor running conition cuz you probably have a piss poor connection on these wires and it's important that they make good contact for proper runing of the trucks electrical system.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 10-18-2003, 12:17 AM   #3
soleeagle
soleeagle's Avatar
There is a reason that that fuse was put there. Obviously you need it because it blew for some reason. I would suggest replacing it and track down the original problem.
Chuck
'85 Chevy Silverado 4X4
'91 Chevy 4X4 Suburban
http://www.cardomain.com/memberpage/545941
soleeagle is offline   Reply With Quote
Old 10-18-2003, 04:33 PM   #4
Tom
Tom's Avatar
When I was pulling the tranny out my friend lowerd when he wasent supposed to and it contacted the power area, causing a spark that knocked out the fuse. Yes we took the battery cables off after that
Old 11-01-2003, 10:51 PM   #5
mutant-jimbo
mutant-jimbo's Avatar
no offence bro, but thats why when you look in a chiltons or haynes manual, under any how to- the first step is always "unhook the battery"
p.s. hooking up the battery backwards will also knoxk out the fusable link. <--been there, dun that
"Texas is an outrage when your husband is dead, Texas is an outrage when they pick up his head, Texas is the reason why the presidents dead"-bullet by The Misfits
mutant-jimbo is offline   Reply With Quote
Old 11-01-2003, 11:32 PM   #6
Blue Beard
Blue Beard's Avatar
Sounds like something that was after market..........but definately put it back till you find the problem.
Contact GMC Pauls, he's been very helpful in the past with wiring issues....
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
