Old 03-20-2017, 01:24 PM   #1
wwdd77
Not your Typical 9C1 swap
Changed over from leafs to the Triangulated 4 links from the 9C1 rear. I had to pretty much scrap all outer mounts, but had new brackets bent up and fit outside the frame rails to use stock upper and lower control arms. Made up some adjustable solid shocks until I get final weight of truck to install coilovers.
Lower arms are level at ride height, upper arms are 3 degrees pointing downward.
wwdd77 is offline   Reply With Quote
