This is really starting to piss me off!
![]() One of the U-bolts on my truck does NOT want to come out. The only thing keeping this U-bolt in place is rust. I undid the nuts, and banged upwards with a large hammer; it stayed stuck in place. I cut the U-bolt in half, and one side came out without much trouble, but the other side is stuck firmly in place. I bathed it in PB Blaster and then banged on the remaining half of the U-bolt; it wouldn't come out. I then placed my jack on the bottom of the threads and lifted the whole back end of the truck in the air and banged downward on the trailing arm and it still won't come out. I'm starting to run out of ideas. Anyone have a good way to get this damn bolt out?
Mike Lackey '68 C10 |
Try spinnin 4 rear tars
You need a bigger hammer!!!
![]() Maybe try a torch and heat around it and then beat on it.
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
SLICER AND DICIER
I second the heat and BFH, that's what I had to do.
01 Tahoe 22's 2/4 drop and tv's ![]() 68 chevy money pit 51 chevy belair 95 Honda 900RR 05 GMC Siearra (company truck) |
Cantankerous Geezer
I pulled the axle and arms out from under the truck, turned it over and drove the u-bolts out with a sledge. You can also spread apart the trailing arm. It will either need to be replaced or reworked, which will require spreading it apart to clean it out.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
