Not bloated but stiff
My upper radiator hose has become stiff. alot stiffer than i like but not as stiff as the wife likes.... a little humor. it only started this after i did a full tune up on it. i do not see any bubbles in the coolant and i'm not using any either. any ideas. is it a death sentence for teh old 5.7?
driving is in my blood
Re: Not bloated but stiff
Huh? Who squeezes radiator hoses? So its not overheating, not blowing a ton of pressure out the overflow, not blowing bubbles, not using coolant, and running perfectly, sounds pretty good to me.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
My old Ford used to do that, I found out later it had a partial blockage in the radiator from an additive that the service fellow had supplied by mistake, it was past its "use by date".
I've read on other engine forums that it could be a blockage or even a blown head gasket. I was just looking for some input from a vehicle specific form of help. Thanks
Its nothing.
Its normal for a cooling system to be pressurized up to 15 PSI. If there is more pressure than that, the radiator cap will open and allow coolant to go to the overflow reservoir. And I squeeze radiator hoses all the time. Usually its right before I take the radiator cap off. I do that to "feel" how much pressure is in there. I don't want to get burned or make a giant mess. |
#6 | |
From Lancaster Huh, Im outside Oxford about 35 minutes southeast of ya.
It just felt off to me compared to what it was...... Quote:
| Bookmarks |
