03-21-2017, 01:40 PM | #1 |
S10 spring pocket upper bag cups
if you look at the photo, up inside the spring pocket are 9 or 10 tabs, do these have to be removed for the upper bag cup to fit over? my cups wont fit over them.
03-21-2017, 05:49 PM | #2 | |
Re: S10 spring pocket upper bag cups
I remember the ART cups would pressure fit over those because the early ones didnt have a bolt up through the shock mount. try pushing. also, if you have a bolt in cup, make sure its clocked correctly, the bolt is not dead center in the cups especially with offset cups.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
03-21-2017, 06:08 PM | #3 |
I am thinking the same thing of having the wrong cups. i have read here and on the S10 forum numerous threads on bagging s10 and never read anywhere about the tabs having having to be delt with, i will call my supplier and double check. thanks
03-21-2017, 06:12 PM | #4 |
also, i didn't mention that the lower cups , two bolts that mount the cups to the lower control arm don't line up with the shock bolt holes to narrow.
03-21-2017, 07:19 PM | #5 |
Have you run the parts number on the bag/kit? Just by plugging that in a Google search you should be able to come up with what it says it fits.
03-21-2017, 08:17 PM | #6 |
I had a spare set of Air Lift offset cups on the shelf to check, the inner measurement is 5"
03-21-2017, 09:27 PM | #7 |
03-21-2017, 09:29 PM | #8 |
03-21-2017, 11:17 PM | #9 |
honestly, you can get S10 cups brand new for so cheap now a days, it wouldnt be worth selling my set for less and then me buying another set later. bird in the hand and all that.
what is your measurement? I have a hunch they used 5" OD instead of ID. one time my wifes crazy uncles went to mexico for some big fireworks, the kind of big you add a UH sound to the word when you say it, BUUHHHIIIG fireworks. They were 6" shells, and the one uncle dutifully got some 6" pipe to launch them, but got 6" OD. the first one went up about 12 feet and exploded, knocking over the front row of spectators and setting fire to the house roof. the natural response was for everyone to back up. that was a crazy party, crazy the way you need to add "a"'s to the word crazy. like a couple seconds worth.
03-22-2017, 12:44 PM | #10 |
I called the company i bought them from and explained them the situation and they said the S10 p/u bag cups use a 4.5 OD cups. that is what i have and for the life of me i cannot get them to fit. they said also i have to re drill the lower control arm sock holes to make them fit. i would think they would weld them in the cups at the factory to fit the bolt holes in the LCA's.
03-22-2017, 02:09 PM | #11 |
do the bags fit the cups? sounds like they also have some waterfront property for sale somewhere too......
03-22-2017, 02:29 PM | #12 | |
ocean front property in Arizona. i think they frequent this forum often, so i wont say the company name. i will just order a new set from Thorbros, which i should have in the first place. |
03-22-2017, 03:03 PM | #13 | |
I remembered I had a set of thorbecke lowers from when I had new lowers made for my 65, it was easier to flat plate and omit the bottom cup. anyway, they measure 5" OD, the air lifts measure 5 3/8" OD (5" ID) and for good measure I measured the stock springs which are right at 4.5 ID. so 4.5 OD might be really tight. those little clips bend pretty easy, maybe take the upper cup by itself and give it a whack to see if it will seat. Also, make sure your fitting is oriented properly and the line is run properly, it may be hitting on the fitting or line post a picture of your cups!
03-22-2017, 03:35 PM | #14 | |
