03-21-2017, 09:43 PM | #1 |
Timing adjustment
Hey guys. Got a 302 crate engine the the PO put in. At what rpm do I need to set the timing and at what degree? Thanks in advance.
03-21-2017, 09:54 PM | #2 | ||
"I ain't nobody, dork."
Re: Timing adjustment
302? is it a DZ code 302?
Will need more info on engine to recommend what timing to set it at. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
03-21-2017, 10:04 PM | #3 |
03-21-2017, 10:11 PM | #4 |
A stock 305 Id start at like 8 initial advance with vacuum advance disconnected and engine warm,use a timing light
03-21-2017, 10:43 PM | #5 |
He's in Ogden, Utah. At that elevation I would start at 10 - 12 degrees initial timing.
03-21-2017, 10:43 PM | #6 |
DZ is the suffix code for a Z28 302.
For your timing look here to figure it out. http://www.badasscars.com/index.cfm/...d=76/prd76.htm |
03-21-2017, 10:45 PM | #7 |
03-21-2017, 11:02 PM | #8 |
03-22-2017, 06:59 AM | #9 |
Thanks guys. I'll probably set it tonight. So do I set it at 10-12 at idle or do I need it to be at a certain rpm?
03-22-2017, 09:37 AM | #10 |
10 to 12 is only a starting point. At elevation you'll likely be up closer to 16.
Set it with the vacuum plugged to the vac pot and at the lowest rpm it will idle at. Preferably below 700 rpm. |
03-22-2017, 11:48 AM | #11 |
Let me tell you a story about a Ford guy with a motorhome. Similar situation. Dialed in 16 degrees timing as he was told, and it did indeed run the best there. Many of our motors will... I think I have 12-14 degrees into my 402.
Sadly he also had 28 degrees of mechanical timing built into the centrifugal advance of the distributor, so each time he went through the mountain pass on the I-90 he grenaded the motor. Broke ring lands off pistons, the whole deal. And he did this twice believe before he brought the motor in to be dyno'd. The answer there was to put it on the distributor machine and take some mechanical advance out of it. The lesson is that your distributor has a certain amount of mechanical advance built in. If that was designed to work with some small amount of initial timing like 4 degrees and you add another 12, you may have WAY too much at higher RPM. So if it turns out to need that much to run well, do be sure to have the high RPM timing checked with a light at least to make sure it's not wildly advanced.
03-22-2017, 12:29 PM | #12 |
So true dave, but we'd hope with the links stanley got he'd read them and adjust accordingly.
Another for adjusting your mechanical. http://www.crankshaftcoalition.com/w...EI_distributor So, was the ford guy stone deaf? Shoulda heard the loud rattle! |
03-22-2017, 01:53 PM | #13 |
I know, we couldn't figure out why he never heard detonation. I -assume- it was a front-engine motorhome, not a rear "pusher" type.
