03-22-2017, 09:57 PM | #1 |
Fuel pump with vacuum booster
Anyone know how to hook one of these up to your truck??? It didn't come with any instructions on how to hook it up! My truck is a 53 3600 3/4 ton. I am at a loss!!
03-23-2017, 07:39 AM | #2 |
Re: Fuel pump with vacuum booster
Is this a mechanical pump? The vacuum line from the wiper is connected to the pump instead of the carb / manifold. It's possible to use both if you put a check valve between the engine and the Tee for the pump so it doesn't draw fuel/air out of the manifold. You would only want to do this if you're using vacuum brakes or other accessories along with the wipers.
