64-66 what rear tank are you using ?
What is everyone using for bed mounted tanks these days ?
I have a couple of trucks to do a 1960 a 1962 and 1965 all short boxes so i would like to start buying all the same tanks . What is everyone using for carburetor and LS builds ? Thanks guys |
Re: 64-66 what rear tank are you using ?
I have a 30 gal tank and I spent 400 is for every thing.
Here is my 5.3 ls tanks swap part list (also works for carb motors) ●87-91 fuel tank $94.90 ● 87-91 31 gal tank straps $28.75 ● EFI 87-91 fuel tank sender $80.00 ● high pressure pump $70.00 ● fuel lines $50.00 ● high pressure filter $20.00 *Total spent = 343.65 |
The '60-'62 frame is wider than the '65. I used a 22 gallon '78 chevy van tank, straps and sending unit because it doesn't hang as low as the blazer tank and fit's pretty well. I'm planning on swapping in 5.3 L33 in the near future and will use the same tank with an OEM in tank fuel pump. There's probably a couple of threads that would be helpful as well..
LMC top fill tank on my 66 stepside
Really? No 1969 Camaro tanks with a license plate filler? Still contemplating doing this with my 66 for the reason that it's a stepside and I don't want fender or bed filler cap. Tucking it up as tight as I can seems doable without a bunch hanging down, love the license plate filler if it can be done, but wonder if "fuel slosh" toward the filler cap is a problem...I guess I could add a baffle to a new tank...
1966 mustang tank fits nice in back........
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
First generation mustang .Using a stewart warner sender kit for gm gauge.Worked great .And $"s spent are low.
The Snortin' Bull |
53-54 Chevrolet passenger tank from Tanks Inc, comes baffled for EFI use.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
![]() Join Date: Aug 2014
Im using a Boyd welding tank in my 65 with my LS2. Quality and fitment is top notch! Not cheap but excellent tank. Im very pleased with it. Its a top/bed fill.
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
#13 | |
#14 |
#15 |
#16 |
#17 |
Boyd tanks look great and I bet they work great .....A little steep for some of my customers who want to do a budget build . I was just looking at a 85 blazer tank that i was thinking of building a neck to make it a top fill. Anyone try that before ?
#18 |
#19 | |
#20 |
Think I spent 50$ used, clean with the filler neck, locking cap, straps and skid plate. I think it is the bigger of the Blazer tanks - 33-35 gal. I think there may have been a smaller one around 25 - 27 gal. that doesn't hang as low. I actually bought a sending unit that I had to return because it was 4" too short and wouldn't touch the bottom.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
#21 | |
#22 |
I have autometer gauges. what I did was drill out the rivits to the sending unit and attach a sending unit with the correct ohms to my gauge an wire it in where the old one was. I also instslled a walbro 255 and wired it in to the existing harness. You can do the same and it will work. It may be off a little but nothing is perfectly accurate. I will try to upload pics later tonight to give you an idea of what I did.
#23 |
Moderator
![]() ![]() Join Date: Aug 2011
Doc's Kuston Tanks
https://www.southernrods.com/fuel-sy...fuel-tank.html http://www.aplusrodandkustom.com/ind...16/prd2416.htm
#24 | |
#25 |
speaking of 66 mustang tanks, anyone think this is a good pairing with a 5.3l LS engine? https://www.summitracing.com/parts/a.../model/mustang
