Fuel Tank/ Fuel Pump
PO of my truck has moved the fuel tank to under the bed and cut a hole in the inner side of the bed wall to fill the tank. The hose that connects the filler to the tank has too much of a bend and clicks off every time I fill and it makes me lose my mind when filling up. He also has a stainless fuel cell that he had bought to replace the other setup. I want to put that cell in and redo the filler to a better location that works.
Here is where the question comes in. The fuel cell was purchased with the intention of installing a FIRST fuel injection unit so the tank has the return as well as a fuel pump for the FI. Will I be able to just cap the return and use the fuel pump in there with my carburetor set up that is in there now? This is the spec on the tank/pump/sending Unit: AC Delco EP-381. -6 supply & -6 Return (3/8 bungs & 90 degree -6 elbow to 3/8). Sending unit 0 to 90 Ohms. Thanks for the help! I'll have a tank set up to sell once I am done. |
![]() Join Date: May 2013
Re: Fuel Tank/ Fuel Pump
You need some type of regulator and return for an in tank pump , pretty sure you can regulate it down to 6 psi for a carb with no ill effects , so you will need ,1 supply , 2 return , 3 vent
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
