03-24-2017, 02:03 PM | #1 |
Old member
Door's
Bought new door seals and weather strips for the Ramp truck last weekend at the Run to the Sun car show in Myrtle Beach SC.
It's a nice day so I started on them. Both doors need all new stuff. I also have been waiting to do this to make door panel patterns to have new panels made like I did on the 71. Pretty simple panels that cover up the whole door almost.They work great for the doors that had holes cut for speakers. Hey guy's where can I get the nuts that go in the door for the arm rest's. I need just one.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 03-24-2017 at 02:09 PM. |
03-24-2017, 02:58 PM | #2 |
Re: Door's
The holes are square so I used license plate inserts and they seem to be holding just fine.
03-24-2017, 03:28 PM | #3 |
Re: Door's
I can't remember the proper name of these (capture nuts?) but I found some at my local Ace Hardware.
Good luck on the truck Sam |
03-24-2017, 05:55 PM | #4 |
Re: Door's
cage nuts. got some at fastenal
03-24-2017, 07:50 PM | #5 |
Old member
Re: Door's
Thanks guy's I'll look for them tomorrow. Lowes didn't have anything.
I thought about the plastic nuts for tags but they are to big for the opening. I had a set of the plastic nuts for head light adjusters worked perfect.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 03-24-2017 at 09:21 PM. |
03-25-2017, 12:47 AM | #6 |
Re: Door's
I got a cheap tool from harbor freight that is like a rivet gun but it rivets a threaded insert in there. Worked amazing po tried tack welding a nut there eventually it just rusted off
71 C10 Finally took a leap and did the 5.3 4l80e swap. Running the Holley Terminator Xmax. Still working bugs out. |
03-25-2017, 07:15 PM | #7 |
Old member
Re: Door's
Got the pattern for both doors so Monday i will drop them off at the interior place to have them made up.
Pretty simple door panels nothing to really do but make the doors look a little better. Going to be like the 71's.
03-26-2017, 07:25 PM | #8 |
Old member
Re: Door's
Cleaned up the top door trim today. I want be needing new ones now.
