03-24-2017, 04:49 PM | #1 |
AC/Heater Controls
I tried searching with no results. Will an 73-87 AC/Heater control work in a non AC truck?
Thanks Rick |
03-25-2017, 03:09 AM | #2 |
Re: AC/Heater Controls
The A/C temp control 83-87 will work with any 81-87 if the A/C parts are from the same yr 83-87
But can be made to work 73-87 But on the 73-80 few parts are a little different. so try to get a the same yr A/C parts for the hole set up. When your doing your switch. A donner truck best bet.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
03-25-2017, 07:35 AM | #3 |
Thanks Pontiac, the search begins.
