Old 03-24-2017, 05:32 PM   #1
scoot_mcgrute
Temp Sender
Hey guys, working on my 5.3 swap and the adapter that I bought for the temp sender uses a 3/8 NPT and the factory sender looks to be 1/2 NPT.
Does anyone know of another temp sender with the same resistance so that it would read correctly on the gauge?
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 03-24-2017, 05:49 PM   #2
my56chevytruck
my56chevytruck's Avatar
Re: Temp Sender
Just a quick question, couldn't you contact the manufacturer of the gauges and ask them this?? Just to make sure you get it from the right people is what I'm thinking.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 03-24-2017, 05:50 PM   #3
scoot_mcgrute
Re: Temp Sender
I'm using the factory gauges
1966 Army Truck
Old 03-24-2017, 06:08 PM   #4
scoot_mcgrute
Re: Temp Sender
Found this in another search (I've tried multiple terms and never got anywhere), the TS6 sending unit is what I've got. Posting it here for anyone else wondering the same thing.
Standard Motor Products #TS6 fits most GM temp gauge applications from the 60's on up to around 79 or 81. It has 1/2" threads and a "nail-head" type connector. It specs out at 368 Ohms @ 100F and 80 Ohms @ 220F.
1966 Army Truck
Old 03-24-2017, 06:55 PM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Temp Sender
Need to go to lectriclimited and get the correct sending unit.
https://www.lectriclimited.com/elect...ing-unit-87590
And be done with it.
http://67-72chevytrucks.com/vboard/s...d.php?t=525139
Old 03-25-2017, 12:19 AM   #6
Captainfab
60-66 Nut
Re: Temp Sender
Here's another option.
http://www.67-72chevytrucks.com/vboa...d.php?t=726700
Old 03-30-2017, 10:51 AM   #7
scoot_mcgrute
Re: Temp Sender
Originally Posted by Captainfab View Post
Thanks for that link, the cutaway really helped me out a bunch. I ended up re-threading the sensor to 3/8NPT, worked like a champ!
1966 Army Truck
