03-25-2017, 11:34 PM | #1 |
Using a smaller master cylinder on the JB7 brakes (13" drums) ok?
I should start by saying - I upgraded to the JB7 brakes from a 3/4 ton (larger front calipers, rotors and 13" rear drums) 2 years ago on my truck which was originally a half ton. I did not touch the Master Cylinder, just replaced the flexible lines and everything bolted up fine.
The JB7 system came with a larger Master Cylinder and booster vs what my truck currently has. I recently came into possession of the larger MC and booster, but it appears the front/rear fittings on that MC are reversed in position on larger MC vs what I have now. This means to install it, I would either need to replace the lines from the proportioning valve to the MC, or bend the lines to fit the new positions. So far, I have had no issues running the smaller MC, it seems to work fine. I do wonder though - if GM designed the system and thought a larger one was needed, maybe I should consider getting the proper one on there. Or maybe its pointless to switch them out. The main difference I can see - the smaller MC has a 1-1/8" bore, the larger one has a 1-1/4" bore. What do you guys think or know, I know little about brake system design, other than the basic concept of how they work. |
03-26-2017, 06:56 AM | #2 |
Re: Using a smaller master cylinder on the JB7 brakes (13" drums) ok?
The larger bore will displace more fluid faster . This will result in a harder pedal . If you have a slightly soft pedal now this may be desirable . The larger bore was for the larger caliper capacity .
If you have it in your possession now with out having to purchase it I would try it . You don't have to bend or replace the lines. There is brass adapters that will convert to accommodate the size change . I did this when I was going thru trying to find a master to work with my rear disc conversion . My local parts store had them . |
03-26-2017, 08:07 AM | #3 |
Thanks for input - do the front and rear port displace the same amount of fluid?
I figured they had different diameter ports on the MC so you wouldnt try to switch the spots. Maybe its just because of the line sizes? |
03-26-2017, 08:25 AM | #4 |
usually the fronts have a larger line because they take more fluid than the rear small cylinder drum brakes . If you have plenty of slack try to see if you can move the lines . Mine had a coil in it and was not to bad to change positions so I could give it a try .
03-26-2017, 07:39 PM | #5 | |||
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-26-2017, 11:17 PM | #6 |
I have a Burb that was originally a 1/2 ton but I converted it to a 3/4 ton front and a rear from a 1 ton with the big brakes. I left the stock master in place and it has always worked well for daily driver duties and towing. I've also had a few 3/4 ton Burbs with the proper master cylinder, they have a harder pedal due to the larger master cylinder. I prefer the 1/2 ton master due to it's softer pedal feel... BUT, there is one drawback. You have to make sure the rear brakes are properly adjusted or you end up with excessive pedal travel.
-Andy '77 K5 Blazer '78 K10 Shortbed '78 C20 Suburban '79 K30 Crew Cab Dually '84 C10 Short Stepside '88 K20 Suburban |
03-27-2017, 09:32 AM | #7 | |
I used a smaller bore MC in my dually to help increase line pressure when I went from the Hydra boost set-up to vacuum brakes.
03-27-2017, 10:18 AM | #8 | ||
03-27-2017, 10:36 AM | #9 | |
03-27-2017, 09:19 PM | #10 |
No, you will be required to apply more pedal pressure to achieve the same line pressure. Harder pedal means more work to get the job done.
03-28-2017, 12:49 PM | #11 |
driving is in my blood
Larger bore master will result is less pedal effort for same amount of line pressure put to braking system, meaning softer pedal. Hence the reason everyone with an 88-98 puts 99+ master cylinders on for harder pedals, because the 99+ has a smaller piston.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
03-28-2017, 10:31 PM | #12 | |
Like I said before, I have personal experience with the exact setup the OP is inquiring about. I have run both master cylinders, the smaller bore provides a softer pedal FEEL and a little more pedal travel. GM themselves are aware of that fact too. One example is the 3rd gen F-body, the dealers used to install the smaller disc/drum master on the disc/disc cars when the customer's complaint was a hard brake pedal.
