03-26-2017, 01:24 PM | #1 |
6.0 into a 72 K10 Do I have to move tranny forward?
Need a little help here guys. In the process of swapping a 6.0 LQ4 into my 72 K10 and I cannot get engine back far enough to mate the TH350. I am using LSX innovation swap plates at the farthest hole forward. The head touches the firewall before I get the tranny bolts in. I have removed part of the mount pads off the frame to get it closer but can't get it all the way in. Any help appreciated.
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped |
03-26-2017, 03:26 PM | #2 |
Re: 6.0 into a 72 K10 Do I have to move tranny forward?
Good time to put in a 4L60e. That will push the engine forward a couple inches.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
03-26-2017, 04:11 PM | #3 |
Tranny shifts good and is recently rebuilt....
Looks like the stock crissmember won't work either..
03-26-2017, 05:05 PM | #4 |
Nope, you need one for this specific conversion. $300-$400
03-26-2017, 10:47 PM | #5 |
I think you can use off road designs crossmember to solve the clearance issues. Otherwise you looking at dirty dingos 4x4 crossmember
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
03-26-2017, 11:30 PM | #6 |
Post Whore
I used ebay adapters on mine..had no clearance issues...they kept the rear of the LS engine in the same postion as the smallblock..didn't have to move anything...until I put that nv4500 behind it..then I had to move my trans crossmember back 1 1/2"
03-31-2017, 02:09 PM | #7 |
Picked up the Dirty Dingo crossmember kit today after talking on the phone with them. Still had to mod the firewall a bit as valve covers are almost touching stock firewall with TH 350 in stock location. Don't want to change tranny or driveshafts as truck drives smooth...Pic to follow.
03-31-2017, 02:24 PM | #8 |
Do you know what motor mount pads those are? Looking for a part number.
Thanks, Nick |
03-31-2017, 02:26 PM | #9 |
i Can look after work..you mean the 3 bolt stock Chevrolet with the single bolt to crossmember?
03-31-2017, 02:27 PM | #10 |
04-01-2017, 03:46 PM | #11 |
Here's a pic... might be 2282 xxxx? Good luck
