![]() Join Date: Jun 2014
Stock A/C Clutch Pulley Diameter5" or 6"?
Going to order a new compressor for my 71 C10 w/factory A/C and one of the questions I can't answer is the diameter of the clutch pulley. Options are one with a 5" or 6". If my truck wasn't 100 miles away I could just go out and measure it.... Searched the forums extensively but can't find that tidbit.
TIA, Randy |
![]() Join Date: May 2010
Re: Stock A/C Clutch Pulley Diameter5" or 6"?
I can't measure mine since I'm farther from my '69 than you are from your truck. But this may help. I found a new compressor (R12) on Craigslist for $50. However, it has a smaller pulley than my original. So, my guess is you want the 6" pulley. Here are pictures of my original and the new one for reference.
20' Daredevil (Ret)
![]() Join Date: May 2003
If it helps, the OEM pulley on my '72 K20 is 5".
Who Changed This?
![]() Join Date: Jan 2013
Mine ('70 C20/402) is 6". Maybe the difference is BBC Vs SBC?
~Steven '70 Chevy 3/4T Longhorn CST 402/400/3.56 Custom Camper Simi Valley, CA Last edited by Steeveedee; 03-28-2017 at 04:32 PM. Reason: deleted unnecessary info |
I would think if you had low gears then the 6" would be better as it would turn the compressor a little slower. If you have high gear ratio a 5" would be better.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
