Old 03-26-2017, 10:14 PM   #1
the idiocracy
TH350 question
Hey guys...I am looking to put a th350 in place of the 3 speed manual and I need a little help figuring out what parts fit. Hoping I can draw on some expertise in here.
Engine is a 250 inline 6. I know I can use a standard SBC starter, but I am confused about the flexplate. Anyone done this swap that can offer some helpful hints?
the idiocracy is offline   Reply With Quote
Old 03-27-2017, 09:53 AM   #2
old51sedan
old51sedan's Avatar
Re: TH350 question
I'm getting ready to pull the 250 with 3 speed auto out of my truck, going to replace with a 292 and 200-4R. Also have plans to pull the steering column and replace with a tilt column. Sounds like everything you may need but not sure where you are located.
old51sedan is offline   Reply With Quote
Old 03-27-2017, 10:15 AM   #3
camtoys1
Re: TH350 question
i just did this sat you need a 153 tooth flex plate at first i had a 168 tooth it was to big and the starter would not even bolt to the block so go with a 153 and your set
camtoys1 is offline   Reply With Quote
Old 03-27-2017, 06:43 PM   #4
BCOWANWHEELS
Re: TH350 question
I like 3 on the tree , trouble free after almost a million miles. a th350 is good but not this good
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
