03-27-2017, 11:20 AM | #1 |
66 C10 Emergency Brake Handle and Bracket
trying to locate a good photo or instructions how to reinstall this part. thanks!
03-27-2017, 11:22 AM | #2 |
Re: 66 C10 Emergency Brake Handle and Bracket
oh.. forgot to mention i think this one goes under the dash somewhere. i dont have an opening in the floor.
03-27-2017, 11:38 AM | #3 |
It's Better With Nitro
Should be similar to this:
The cable goes through the rectangular hole under the steering column opening.
03-27-2017, 11:55 AM | #4 |
perfecto! thanks!
03-27-2017, 08:25 PM | #5 |
I don't want to hijack your thread but can anyone tell me the name of the black plate that mounts the brake handle to the bottom of the pedal frame? Does anyone have an extra?
03-27-2017, 08:54 PM | #6 |
No worries
I'm trying to figure this out as well Not sure which part your asking about? Hopefully I'm not missing that too! |
03-27-2017, 09:48 PM | #7 |
Thanks, The part I identified (& to buy) is black, has two bolts into the steering column one bolt into the under dash pedal mount and the brake handle & ratchet are also bolted to it. I think the clutch bumper is also mounted on it. It's kind of the do everything part on the steering column.
I have some extra hand brake parts if anyone wants to trade. Thanks Again. |
03-27-2017, 10:39 PM | #8 |
Sounds like your talking about the plate that mounts the steering column up as well as supports the parking brake ratchet. Should be fairly easy to find a used one but I don't have a parts truck
03-28-2017, 10:36 AM | #9 |
I've always referred to it as the steering column mount bracket.
03-28-2017, 10:17 PM | #10 |
This piece I believe?
03-29-2017, 09:21 PM | #11 |
03-29-2017, 09:25 PM | #12 |
Steering column mount bracket like Vin63 said is what I would call it. Dont think they are reproduced..
