03-28-2017, 11:53 AM | #1 |
In tank Fuel Pump ideas?
In my 66 Gmc I have a fuel injection motor and while now the tank works fine, but is having some leaking issues; and it's only a 10 Gallon tank. So I'm searching for a new tank, with the pump inside the tank to help out. I know of Boyd's tank that fit but is a steep price. So are there other options, or can I stick a fuel pump in say a LMC tank or a different brand and be okay?
03-28-2017, 04:37 PM | #2 |
I'm just glad to be here!
Re: In tank Fuel Pump ideas?
I have seen people run the 25 gallon Blazer tank from a 1987 K5. That was a fuel injected engine that year and had an in tank pump.
You can order the tank (32-5945) and the sending unit (32-4067) from LMC. http://www.lmctruck.com/icatalog/csb/full.aspx?Page=57 Use the correct in tank pump for the fuel requirements of your engine, and install it on the sending unit.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
03-28-2017, 08:36 PM | #3 |
1965 Chevy C10, 2005 4.8L/4l60
Imo, Boyd's are worth the $. You don't have to get the in tank pump option. I run an external pump and have for 8 ish years with no issues.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
03-28-2017, 08:54 PM | #4 |
I bought a Boyd's non -fi tank and had a holley blue electric pump on it
The tank was great but man was that pump annoying. To be fair, I had the pump in a "dead headed" no return system which didn't help the noise. Ended up with a Fi-tech fuel injection and had to install a Tanks inc. retrofit pump in the tank and couldn't be happier. Tanks inc. Was the cheapest route I found for the retrofit but probably would have been money ahead just purchasing the FI tank from Boyd's in the first place(had I known). Good luck! |
03-28-2017, 09:41 PM | #5 | |
How was the install of Boyds? Fit like a glove with no real problems? |
03-29-2017, 01:04 AM | #6 |
60-66 Nut
Here are a couple other ideas.
http://www.tanksinc.com/index.cfm/pa...rod/prd216.htm http://www.tanksinc.com/index.cfm/pa...rod/prd114.htm
03-29-2017, 07:52 AM | #7 |
I have a pierburg pump, stock for some Mercedes vehicles. I have never had any heat issues and I live in Texas,
Pierburg pumps aren't cheap but they are quiet and built well. This is what I have and where I got it.been running since 2010. http://www.turnkeyenginesupply.com/fuel-pump-pierburg/
