03-28-2017, 07:11 PM | #1 |
New Gauge Cluster - Truck Wont Start
1971 Chevy C10 - Fuel Injected and does have a computer on the truck.
I just swapped the entire gauge cluster for a brand new one from Classic Industries. Hooked it all back up and go to start the truck and nothing happens. I am not too well rounded on vehicles, just know the basics. Any help would be appreciated. Thanks |
03-28-2017, 08:11 PM | #2 |
Re: New Gauge Cluster - Truck Wont Start
In Gear and not in Neutral or Park?
Don't ask how I know this When I restored my dash cluster I dropped my steering column down to allow enough room for removal and reinstall. Had the cluster in the dash and went to test the lights and fire up the engine. Engine would not fire Scratched my head for a while and then it dawned on me that the column was still unattached and the gear selector had dropped in gear. Lifes little lessons Good Luck |
03-28-2017, 08:36 PM | #3 |
If it's not as simple as in gear, start tracing the purple (crank) wire from the key and on through the neutral safety switch at the base of the column, from where it goes to the starter. Got to be in that wire somewhere!
03-28-2017, 08:41 PM | #4 |
You could be right Dave, I forgot to mention the neutral safety switch.
03-29-2017, 06:33 AM | #5 |
It happened to be that the gear shift was not in park!! It's funny how the little things are so easy to overlook. Well, I guess you live and learn.
Thanks again. |
03-29-2017, 09:19 AM | #6 |
Do you have an ls engine , if so check your , crank wire , and 12 volt run wire , you probably pulled one off messing with the dash , next cam , and crank sensor conections , if one of those came lose it wont run either , I had one pop lose hitting the brakes hard in reverse , let us know
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
03-29-2017, 09:35 AM | #7 | |
Thanks |
03-29-2017, 12:13 PM | #8 |
Good job Sam, guessing that one right off the bat!
03-29-2017, 07:44 PM | #9 |
Been there and definitely did that!
It took me a hour or so to figure my C10 wouldn't start in gear. Glad your up and running KJH90 Good luck |
03-30-2017, 03:47 AM | #10 |
We need some pictures!
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
03-31-2017, 07:55 AM | #11 |
Flag
03-31-2017, 08:19 AM | #12 |
flag twice
I aint nobody DORK 1972 Cheyenne super k10 swb 350 4speed posi hooks 1934 ford 3 window blown 355 1969 Camaro hugger orange hounds tooth |
03-31-2017, 08:30 AM | #13 |
Lame no one here will click on that cap anyway.
