Old 03-28-2017, 11:30 PM   #1
a32axo
Want to drop rear about 1 inch more and better ride
What's up, got a 1970 gmc c15 shortbed.
Front drop with 2.5 spindles and og coils cut 1 turn
Rear major ? It has 3 leafs only. A lot of bed roll shocks prolly gone
From floor to gender lip 28 inches front 31 inches rear
Got more wheel gap in rear fronts are tucked
What's the best way to get the rear to where I want it about
1-2 inches lower.
a32axo is offline   Reply With Quote
Old 03-29-2017, 01:49 AM   #2
bbbc10
Diggin The SquareLife
Re: Want to drop rear about 1 inch more and better ride
jus buy shackles
bbbc10 is offline   Reply With Quote
Old 03-29-2017, 08:43 AM   #3
hewittca
hewittca's Avatar
From the looks of it, you aren't really that low in the rear so I would assume your rear hasn't been flipped to the top side of the leafs? If it hasn't, then I agree, shackles will get you 1-2 inches. If you don't like those rear springs, you can replace them with the full spring packs and then flip the rear, but it's hard to say where that will put you compared to where you are now. Either way, I think 2" extra would look perfect.
Builds: Green Gus the 68 C10 ; Bluey the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 03-29-2017, 08:53 AM   #4
a32axo
Hasn't been flipped, only 3 leaf springs, the bottom then 3 also they might've been beaten cuz they look flattened out a little
Old 03-29-2017, 08:58 AM   #5
hewittca
hewittca's Avatar
Hmmm, then at this point it's a matter of personal preference I think. You can either keep working with the beat up setup you have, or start from scratch with unmolested leafs and go from there. I'm in the same boat actually, I have heated and cut coils on my truck and want a few more inches. The smart move (to me) would be to replace the hacked parts and add the proper lowering components from there.
Old 03-29-2017, 09:11 AM   #6
a32axo
That's what I'm thinking but before I go buying stuff need to figure it out should I just buy q set of drop leafs if so 4 or 5 inches or should I buy a stock set of leafs and do a flip kit
Old 01-17-2018, 09:26 PM   #7
a32axo
Finally got it lowered in the rear don’t know how much , did a flip kit with stock shackles.
Old 01-19-2018, 11:39 PM   #8
Speedracer39
Speedracer39's Avatar
Looks good—— here’s my 72 with new leaf springs —- removed the overload spring and installed flip kit and c- notch. I’m planning on installing drop shackles to drop the rear.
Speedracer39 is offline   Reply With Quote
Old 01-20-2018, 12:04 AM   #9
a32axo
Looks good, it looks like I’m lower then u. I won’t go any lower if I do c notch will be required. I’m on 22s urs look like 20s
Old 01-20-2018, 01:19 AM   #10
Speedracer39
You are correct 295 40 20 on the rear. I think my springs being new are keeping me alittle higher in the rear than I want to be. Thinking a 2 drop shackle will put me in the ballpark.
