03-29-2017, 12:53 AM | #1 |
Want to upgrade to a BBC 4 core radiator, what is needed?
Looking to upgrade a 76 C10 to a BBC four core radiator. The truck currently has the stock 350 engine and stock radiator.
Will I need anything else besides the following parts? Upper mount panel https://www.brotherstrucks.com/75-80...tinfo/RSC8003/ BBC Shroud https://www.brotherstrucks.com/73-87...tinfo/FS07387/ New rubber pads https://www.brotherstrucks.com/73-91...tinfo/RRP8704/ New radiator mounts https://www.brotherstrucks.com/73-80...tinfo/RSM8001/ Thanks in advance, Wes
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
03-30-2017, 12:18 AM | #2 |
Re: Want to upgrade to a BBC 4 core radiator, what is needed?
you wont need the core support mounts to install your new radiator.just the shroud, upper mount panel and the rubber pads...you got it covered,
03-30-2017, 03:14 AM | #3 |
03-30-2017, 09:38 AM | #4 |
At the body shop.
And possibly nut serts for the top of the core support.
My 77 wasn't threaded on the topposite of the core support.
" That didnt make it any newer " " Dont antique the equipment " |
03-31-2017, 12:23 AM | #5 |
03-31-2017, 10:18 AM | #6 |
03-31-2017, 11:50 AM | #7 | |
At the body shop.
3/8 x 16 where a perfect fit.
03-31-2017, 12:08 PM | #8 |
03-31-2017, 12:23 PM | #9 |
You will get better cooling with a modern 2-core aluminum replacement. Instead of 4 small rows, they have 2 big rows. Air flows through them better and they have a better BTU rating. Even the cheap alum/plastic replacements from your local chain auto parts will work. I have one in my dually cooling my 454 and I have no issues keeping things cool while towing with the A/C on in Phoenix in August.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
04-02-2017, 02:28 PM | #10 |
Spectra Cu730 radiator is a direct replacement for the 454. Works great
72 2wd k5 blazer 86 c10 "Red",76 2wdK5 "Bertha",77 2wdK5 "48",79 c10"Buster" GONE |
04-02-2017, 04:30 PM | #11 |
At the body shop.
I have one in my '73 it wasn't perfect, was just a shade to tall made the shroud all wonky.
