![]() Join Date: Feb 2016
1966 C10 American Racing Torq Thurst II - Help Please
Trying to determine the best fit for the truck. I have 2.5" front drop spindles and 4" rear drop springs. I am running a 396 bbc. The rotor bolt circle is 5"x5". i am being told by Western Chassis the best backspacing would be 3.5" to 4".
I am way out of my league on this. I am use to staying stock. Any experience or help would be appreciated. thanks! |
Moderator
![]() ![]() Join Date: Aug 2011
Re: 1966 C10 American Racing Torq Thurst II - Help Please
Take a moment and watch this video.
https://www.youtube.com/watch?v=pIqR8EQLISc&t=10s Then you can print off this form: http://www.thewheelsmith.net/images/...0spec-form.pdf Watch the video again.
homework. thanks!!
Never Ending Projects
You can't figure your backspacing until you know how wide your wheels are going to be. Very common for these trucks to use a 4.5" backspacing on an 8" wide wheel. 7" would only need 4". 6" would need 3.5". 9" would be 5.5". See how it can make a difference.
And this is just general info. Changes in suspension, brakes, etc. can make these numbers different. Measure, measure, measure.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Thank you. This is why I'm asking
Don't want to do this twice 👍 |
My torque thrusts are 8" wide with 4.5" backspacing. Stock rear width.
It's still a work in progress, so I don't have a lot of photos of it, and none with the fenders on unfortunately.
But you didn't answer the question. How wide to you want to run? No one can tell you what back spacing you might need until we know what width wheel you are planning to run. The numbers I posted give you the most common recommended BS to the width of the wheel.
![]() Join Date: Jan 2011
Then what diameter. That can be an issue in the front. Then the tires you want to use can have an effect in the rear with running out of room in the back.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
not really sure on the diameter nor width. thinking either 18" or 20"
i may end up borrowing a tire/rim from a buddy to see how it looks. sorry to say i am visual and this is a tough one. i do appreciate everyone's help though ![]() |
#13 |
These are 17x8 with 4.5" BS. Tires are 235/60-17.
#14 |
Mine were the same I believe, 17X8 with 4.5 back spacing and 17X7 up front.
#15 |
#16 |
I run 18" x 8" in the front and 18" x 9" in the rear on my 64. Rims have 4.5" Backspacing on the front and 5" Backspacing on the rear.
Tires are 255/60R18 in the front and 265/60R18 in the rear. The rears have a tad to much side wall bulge as they rub occasionally on the inner wheel tubs. Truck has about a 4" drop in the back and a 3.5 drop in the front using CCP drop spindle with 1" lowered belltech spring. |
#17 | |
![]() Quote:
Sam |
#18 |
