03-29-2017, 07:36 PM | #1 |
Need Advice on Steering Column Problem
So I loosened my steering column enough to slide the shaft out to change the lower bearing. I got the shaft out and replaced the adjusting ring, bearing and spring. I'm now trying to put it back together and it's like it's too long now. I can't get the column to go back where it was so I can bolt it back in. Any thoughts on this?
Posted via Mobile Device |
03-29-2017, 08:01 PM | #2 |
Re: Need Advice on Steering Column Problem
Can you post a couple pics?
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
03-29-2017, 08:26 PM | #3 |
What do you want pictures of?
03-29-2017, 08:58 PM | #4 | |
The Older Generation
What year is your truck? Tilt or non tilt? Manual or automatic? It makes a difference. LockDoc
03-29-2017, 09:00 PM | #5 |
It's a 1969 no tilt. It's a 4 on the floor but it may have been a converted 3 on the tree.
03-29-2017, 09:09 PM | #6 | |
LockDoc
03-29-2017, 09:17 PM | #7 |
03-29-2017, 09:18 PM | #8 |
I'm not sure what the upper shift collar is. The ring and bearing are in correctly.
03-29-2017, 09:23 PM | #9 |
I'd like to see a pic of the lower column
03-29-2017, 09:30 PM | #10 | |
The shift collar is the part that the shift lever would have fit into. LockDoc
03-29-2017, 09:40 PM | #11 |
I did not take that off. I'll get a picture tomorrow and post it. I've given up for the night. This truck was pieced together from a couple different trucks by the PO so I don't know the entire history. The odd part is that it seemed to work fine before the lower bearing failed. I'll post tomorrow and thanks for the help.
03-29-2017, 09:48 PM | #12 | |
I would say that if it worked before you have something put together wrong. LockDoc
03-29-2017, 10:11 PM | #13 |
I was just looking at the shop manual and I see that my upper shaft has a collar that looks to be pressed on and it's right above the splines on the lower end. So my thick washer is up against that instead of up against the coupling clamp like the manual shows. If that collar wasnt there I think I'd be fine. This is really confusing now. I'll take a picture tomorrow.
