Re: Tail Light problem .Any help appreciated
Did you have tail lights before the alt change? It's usually a ground problem on the tail lights. Run a wire from the tail light buckets to the frame.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
All light worked before the alternator change. I had already dealt with buckets and making sure I had good grounds when I put LED replacement 1157's in them.
The ground off the battery neg to sheet metal was a worn down with about half the stranding gone so I cleaned that up and regrounded it. No change
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Checked fuses?
Start running the wires from the brake light switch. I would strongly suggest you get a wiring diagram( they are available on line) so you know what color and where they go. A 12volt test light will be invaluable to you. Good luck!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Checked fuses - OK. Have factory shop manuals. I am just not good at chasing electrical gremlins. Should I not start before brake light switch?
Maybe where the wires come off voltage regulator or horn relay? (not sure which one) |
![]() Join Date: Jul 2009
If you look at the wiring diagram for your truck you will see that the only things that the two circuits (taillight/brake-directional) share is a common ground and the headlight switch.
The tail/tag lights are fed directly from the headlight switch by a brown wire. The brake/directional circuits are routed thru the brake switch and then thru the turn signal switch connector. The left directional wire is yellow and the right is dark green. If neither circuit is working then I would start at the headlight switch and work thru to the common ground. |
here is everything you need. FYI: the OE switches are made to give you parking lights BUT when you go to headlights use the running lights turn off unless you modify the switch
![]() http://6066gmcguy.com/parklamp6063.html there is the fix that site has mucho good info and help http://6066gmcguy.com/headlight.html |
