Old 03-29-2017, 11:22 PM   #1
Garagely5150
Gen 1 pbfab dropmember retrofit truss kit
Porterbuilt sent me a retrofit frame truss kit for my gen1 dropmember to fix a cracking issues. It came with new frame trusses and brackets that use existing holes where the engine mounts bolts to the dropmember does anyone have a pic of how exactly it fits ? Any info appreciated
Garagely5150 is offline   Reply With Quote
Old 03-29-2017, 11:23 PM   #2
Garagely5150
Re: Gen 1 pbfab dropmember retrofit truss kit
This is the kit
Old 04-01-2017, 05:20 AM   #3
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Your best bet is probably google image search for 'porterbuilt dropmember'. Here is a pic that showed up in the dropmember thread.
Looks like you are going to have to install the inner trusses/braces, bolt up the engine braces and line up the engine braces to the inner trusses/braces so you can transfer the holes for drilling and bolting.
If you can get ahold of Nate, he may have some older gen 2 or 3 instruction that would give you an idea.
1988 Chevy R30 Dually Crew-Cab - Build thread Cummins swap + Bagged and Bodied on Semi wheels, work in progress
Ghostwhite is offline   Reply With Quote
Old 04-01-2017, 11:23 PM   #4
Garagely5150
Thanks !
